Form 2
The most advanced
desktop 3D printer
ever created.
“This is one of the finest desktop 3D printers you can buy.”
Read the Review
“The Form 2 could not be easier to use, and that is by design.”
Read the Review
“Expect very high-quality 3D prints with excellent detail from the Form 2.”
Read the Review
“The best prosumer 3D printer
I’ve used.”
Read the Review
“The most affordable, yet high-quality, 3D printer on the market.”
Read the Review
Build Volume 145×145×175 mmin
Layer Thickness 25 100 microns
Laser Spot Size 140 microns
Laser Power 250 mW
Beam Width (FWHM) 100% Intensity 38% Form 1+ Form 2 160 µm 140 µm
High-resolution 3D Printing
Laser-sharp prints with stunning surface finish.
Slide Peel
Print big, solid parts with lower peel forces and reduced wear on the resin tank.
Resin Wiper
Improve print consistency by removing any particulates from the build area, properly agitating the resin.
Heated Tank
Achieve optimal print conditions by maintaining a consistent internal temperature of 35 °C.
Automated
Resin System.
The Form 2 prints bigger, better. Our new integrated resin system allows for larger prints, less mess, and longer tank life.
Learn more about Formlabs Resins
Always connected.
Stay informed wherever you are. Your Printer Dashboard allows you to access your Form 2 from anywhere.
Start using the Printer Dashboard
Receive alerts when a print starts, finishes, or when a printer requires attention.
Keep track of previous print jobs and resin usage with your Dashboard.
Manage multiple printers as you scale your operation.
Always connected.
Post-Processing Designed for the Form 2
Built to complete the SLA engine, Form Wash and Form Cure streamline and automate your 3D printing process to consistently produce high-quality results with less time and effort.
Learn More About Better Cleaning and Post-Curing
Powerful printer.
Amazing ecosystem.
Everything you need to start printing at .
Order Now
Contact Sales
Interested in designing your Form Cell?
