Meet the Fuse 1
The industrial power of selective laser sintering on your benchtop, starting at
Manage prototyping and production yourself, in your space, at a tenth of the cost of existing SLS machines.
Produce functional parts in 24 hours, without the delays of service bureaus.
165 x 165 x 320 mm build volume for bigger parts and higher throughput.
No supports. Pack the build chamber with as many parts as you can fit and save time in post‑processing.
Selective laser sintering (SLS) uses a laser to precisely fuse nylon powder into lightweight, robust parts.
A Material That Does It All
This isn’t your average 3D printed plastic. Nylon will bend and return to its original form, rather than fracturing suddenly.
Elongation at Break
Nylon 11
35%
Elongation
Nylon 12
12%
Elongation
Elongation at Break
Nylon 11
35%
Elongation
Nylon 12
12%
Elongation
Sturdy Under Stress
Nylon is perfect for structural, load bearing, or mechanical parts.
Tensile Strength
Nylon 11
48
MPa
Nylon 12
50
MPa
Sturdy Under Stress
Tensile Strength
Nylon 11
48
MPa
Nylon 12
50
MPa
Withstand the Elements
Nylon is suitable for high temperature applications and parts that need to tolerate heat.
Heat Deflection Temperature
Nylon 11
130°C
at 0.45 MPa
Nylon 12
154°C
at 0.45 MPa
Nylon 11
130°C
at 0.45 MPa
Nylon 12
154°C
at 0.45 MPa
Always Printing
A removable build chamber enables continuous printing and reduces downtime.
With the Fuse 1, you can print with up to 50% recycled powder.
Reserve Your Fuse 1 Today
Be the first in line to receive the new standard in industrial 3D printing. Make a deposit now; beta units start shipping late 2017.
Contact Sales
Interested in designing your Form Cell?
