Tech Specs
Form 1+
Form 2
Hardware
Dimensions
30 × 28 × 45 cm
12 × 11 × 18 in
35 × 33 × 52 cm
13.5 × 13 × 20.5 in
Weight
8 kg
18 lbs
13 kg
28.5 lbs
Operating Temperature
Suggested 1828° C
Suggested 6482° F
Auto-heats to 35° C
Auto-heats to 95° F
Temperature Control
N/A
Self-heating Resin Tank
Power Requirements
100240 V
1.5 A 50/60 Hz
60 W
100240 V
1.5 A 50/60 Hz
65 W
Laser Specifications
EN 60825-1:2007 certified
Class 1 Laser Product
405nm violet laser
120mW laser
405nm violet laser
250mW laser
Connectivity
USB
Wifi, Ethernet and USB
Optical Path
Open
Protected
Printer control
Push-button
Interactive Touch-screen with Push-button
Printing Properties
Technology
Stereolithography (SLA)
Peel Mechanism
Hinged Peel Process
Sliding Peel Process with wiper
Resin Fill System
Manual
Automated
Build Volume
125 × 125 × 165 mm
4.9 × 4.9 × 6.5 in
145 × 145 × 175 mm
5.7 × 5.7 × 6.9 in
Layer Thickness (Axis Resolution)
25, 50, 100, 200 microns
0.001, 0.002, 0.004, 0.008 inches
25, 50, 100 microns
0.001, 0.002, 0.004 inches
Laser Spot Size (FWHM)
155 microns
0.0061 inches
140 microns
0.0055 inches
Supports
Auto-Generated
Easily Removable
Auto-Generated
Easily Removable
Material Properties
Packaging
500 ml - 1 L bottles
1 L cartridges
Methacrylate Photopolymer Resin
PreForm Software
System Requirements
  • Windows 7 and up
  • Mac OS X 10.7 and up
  • OpenGL 2.1
  • 2GB RAM
Learn more
  • Windows 7 and up
  • OpenGL 2.1
  • 2GB RAM
Learn more
Hardware Requirements
Formlabs Form 1 or Form 1+ 3D Printer
Formlabs Form 2 3D Printer
Features
  • Simple print setup
  • Auto-orient for optimal print position
  • Auto-mesh repair
  • Auto-generation of supports
  • Rotation, scaling and duplication
  • Layer slicer for path inspection
  • .STL and .OBJ file input
  • .FORM file output
  • Auto-mesh repair
  • .FORM file output
Finish Kit
Includes
  • Finishing Tray
  • Scraper
  • Pre and Post-Rinse Tubs
  • Rinse Basket
  • Squeeze Bottle
  • Flush Cutters
  • Tweezers
  • Disposable Nitrile Gloves
  • PEC*PAD Wipes
  • Microfiber cloth
  • Finishing Tray
  • Scraper
  • Rinse Basket
  • Squeeze Bottle
  • Flush Cutters
  • Tweezers
  • PEC*PAD Wipes
  • Microfiber cloth
  • Removal Tool
  • Removal Jig
Contact Sales
Interested in designing your Form Cell?
